battery question
i have an 01 F4i and when i leave it sit for a couple of days, i have to push start it to get her going. when its going, however, i have no problems with it dying or anything. is it time for a new battery or should i just charge the one that is in it?
RE: battery question
it may be more hardcore than that...if it's the stock battery...then i say it needs replacing.
if it's semi new, gots to make sure that it's not your alternator not charging the battery. i ride mines all the time, same battery for like 37K now and still all good...or do i have 38...whatever mang! you need to ride it more that's all it means. |
they sell a battery maintaner for our battery for like $35.00 at your local parts store. It does help the battery during the winter time.
Are you turning your emegency kill switch off when you park it. If you are, dont do that. I had the same problem and the bike will drain its own battery if you do that.
Other then that, Ide say replace the battery Daniel Thompson |
if the battery is older than it might be time for a new one. if its new you'll have to check your charging system. since its not dying once you get going Im assuming that your batter either had no cold crank amps or its just really low
it also may be the rectifier check that to
ORIGINAL: DThompson Are you turning your emegency kill switch off when you park it. If you are, dont do that. I had the same problem and the bike will drain its own battery if you do that. Other then that, Ide say replace the battery Daniel Thompson |
um...i have never heard of that before...that bugger has nothing to do with the battery mang...
in msf, they teach you to use that kill switch too. it's like if you sit on cold concrete, you'll get hemmorhoids... |
ORIGINAL: Tahoe SC um...i have never heard of that before...that bugger has nothing to do with the battery mang... in msf, they teach you to use that kill switch too. it's like if you sit on cold concrete, you'll get hemmorhoids... |
thats why i said the rectifer per it is part of the cahrging system
