battery question
RE: battery question
it may be more hardcore than that...if it's the stock battery...then i say it needs replacing.
if it's semi new, gots to make sure that it's not your alternator not charging the battery.
i ride mines all the time, same battery for like 37K now and still all good...or do i have 38...whatever mang!
you need to ride it more that's all it means.
ORIGINAL: DThompson
Are you turning your emegency kill switch off when you park it. If you are, dont do that. I had the same problem and the bike will drain its own battery if you do that.
Other then that, Ide say replace the battery
Daniel Thompson
Daniel Thompson
ORIGINAL: Tahoe SC
um...i have never heard of that before...that bugger has nothing to do with the battery mang...
in msf, they teach you to use that kill switch too.
it's like if you sit on cold concrete, you'll get hemmorhoids...
