battery exploded.
Old Jul 28, 2006 | 04:04 AM
flashpoint's Avatar
Default battery exploded.
well yesterday, my battery died in the F4i, so i hooked it up to my charger at the recomended voltage and time. it called for a quick charge on the battery of 2v at 1 hr. so i did that and took off, no problems. well this morning, i went to school, then after school went to work. when i get to work, i notice a lot of white residue on my swing arm and tire and rear breaks. turns out the battery was leaking acid all in the box that it resides in, which was in turn leaking out a vent hole in the middle of the box. called and ordered a new battery as soon as i saw this. anyone know how to remove the stains left by the acid? when i was riding home after work (i had to push start the bike) it started raining pretty hard and seemed to wash some of the residue away, except for on the lower part of the exhaust where it kinda melted on there. a couple of other things too. are k&n air filters really worth the $50 or should i stick with the OEM filter. also what is the best replacement spark plugs for the F4i. my bike feels a bit sluggish lately and im thinking its either the plugs or air filter. bike has 20,300 miles on it and still running like a champ, except for the dead battery. thanks in advance guys.
Old Jul 28, 2006 | 04:07 AM
raredogg's Avatar
Default RE: battery exploded.
its called soft scrub should do the trick
Old Jul 28, 2006 | 08:47 AM
dwhite645's Avatar
Or you could put coke on it too. You'll have to rinse that off too though right after.
As for the air filter, I went with a K&N but only because it's reusable. zero performance gains. For spark plugs, just stick with oem ones, I think they're NGK's.
crazie929
Apr 8, 2012 10:37 PM
SHugo
Sep 5, 2009 03:00 PM
tds94probe
Sep 27, 2008 09:48 PM
jwelch
Apr 14, 2007 04:39 PM
1 UP
Feb 16, 2007 10:04 PM
