Battery or Alternator?
Old Jun 14, 2008 | 08:31 PM
Mustangred's Avatar
Default Battery or Alternator?
For the last few days I get on my bike to go ride, turn on the key everthing turns on then I try to start it then just a click. Then I have to jump it off or try to pick up some speed and pop the clutch. So the battery is not keeping a charge or its not being charged by the alternator. I thought the way it goes is if the engine is running and you take off the ground cable and it dies its the alternator. I tried that and thats exaclty what happen so any help.
Old Jun 15, 2008 | 12:24 AM
StrikeAnywhere's Avatar
Default RE: Battery or Alternator?
tried to post 3 times, forum is ****ed
fully charge your battery then go from there............
Old Jun 15, 2008 | 03:27 AM
StreetPower's Avatar
check your voltage when bike is running,,
Old Jun 16, 2008 | 03:28 PM
WOT's Avatar
WOT
Take the battery to your local shop and get it charged and load tested. To tell if the voltage regulator/rectifier is working, park the bike with the headlight facing a wall, rev the engine and see if you headlight dims. If it fluctuates, most likely your reg/rect is working. If you have some testing equipment and a manual, you can diagnose, otherwise just get it to a shop.
Old Jun 16, 2008 | 03:31 PM
Duess's Avatar
Could be...
Battery
Stator
Reg/Rect
What year, make and model bike? When is the last time the battery was changed?
Old Jun 16, 2008 | 04:50 PM
Mustangred's Avatar
I have a 2001 F4i with about 12000 miles, It might be the original battery. A shop down the road wanted 140 bucks for a new one.
Old Jun 17, 2008 | 10:46 AM
WOT's Avatar
WOT
The stock battery is expensive. I bought a no name brand online for $60 and it works fine.
Old Jun 17, 2008 | 11:35 AM
Mustangred's Avatar
Well back to it maybe being the alternator, I had it running and took off the black cable and it died. I thought that normally meant it was the alternator. Thats what happen to me with my car and it did turn out to be my alternator.
Old Jun 17, 2008 | 12:23 PM
CBR Time's Avatar
just throughing this out there, its not afuse is it? theres a 10A for the dash and tach etc
