Barnett clutch issue
Hello I’m having a problem with my clutch my old clutch was slipping in the high rpms and I replaced it with a new Barnett clutch installed correctly and it’s still slipping in the high rpms I think I need a new clutch cable because it’s stretched to almost max tightness so I think that’s the problem if you think any other reason please share
A stretched cable would be the opposite symptom. You would not be able to fully disengage the clutch and would want to jump forward when shifting from neutral to 1st gear. If by stretched, you mean there is no slack in the cable and clutch lever, then either the cable is routed improperly, or it's the wrong one and too short. This would be a slipping situation.
That must be my problem then. I’ll have to mess with it tomorrow and hopefully that will fix my slipping issue if not I will be back lol. Thanks for the help!
