Audi lights and HID's
I installed Audi style lights in my headlamp using these:
http://cgi.ebay.com/2-Flexible-Strip...item3a596db782
I also installed a 35 watt HID kit from DDM tuning. The led's are as far away from the HID bulb as possible. Should I have installed some type of heat shield? How much heat does the 35 watt HID's throw off?
heat shield
yep you should put some kind of heat shield ,especially if you are running hid's . i did that last year and the bulbs on the high end( go out in 3's) went out from the heat from the hid's. i used the metal foil tape this time around when i added the halos, but you definitely should,its a job you don't want to do over and over again. this is how the new job came out:
