anyone purchase a OEM CCTL before???
does it come with the screw in the middle?
so all u need to buy is the gasket and the tensioner itself? that's it? and u can re-use all the mounting bolts and washer right? thanks. |
Originally Posted by playb0i
(Post 923605)
so u need the screw/washer for the new tensioner?
what about the 2 mounting bolts/washers? need new? or reuse old ones? any adjusting needed on the new tensioner? or just plug and play? |
I reused the old mounting bolts. Once you've put in the new tensioner, pull out the key and then put in the washer and screw on the end. I used a new washer
when u purchase the new tensioner, does it come with a screw and washer on the back of the tensioner?
asd
http://partsfinder.onlinemicrofiche....artsfinder.htm
here is a web site where u can get all the part # u have to buy every washer ,bolt, nut ,casquet separatly ! its always better to use new stuff |
(Post 923864)
but there is no room to install the washer and bolt in the back of the tensioner, once its in its place.
can u do it before installing the new tensioner? |
no u have to install it when its in place
