anyone purchase a OEM CCTL before???
Old 05-21-2010, 01:06 AM
Default anyone purchase a OEM CCTL before???
does it come with the screw in the middle?
so all u need to buy is the gasket and the tensioner itself? that's it?
and u can re-use all the mounting bolts and washer right?
thanks.
Old 05-21-2010, 02:03 AM
rd91si's Avatar
thanks.
No it doesn't I reused mine.
Old 05-21-2010, 10:31 AM
so u need the screw/washer for the new tensioner?
what about the 2 mounting bolts/washers? need new? or reuse old ones?
any adjusting needed on the new tensioner? or just plug and play?
Old 05-21-2010, 03:13 PM
I reused the old mounting bolts. Once you've put in the new tensioner, pull out the key and then put in the washer and screw on the end. I used a new washer
Old 05-21-2010, 05:05 PM
when u purchase the new tensioner, does it come with a screw and washer on the back of the tensioner?
Old 05-21-2010, 07:43 PM
oxyg3ne's Avatar
Default asd
http://partsfinder.onlinemicrofiche....artsfinder.htm
here is a web site where u can get all the part # u have to buy every washer ,bolt, nut ,casquet separatly ! its always better to use new stuff
Old 05-22-2010, 01:47 AM
no, it comes with a lock. install the new cct using the old mounting bolts once its in take out the lock(which engages the tensioner) then put the old bolt and washer in the back of the cct
Old 05-22-2010, 02:39 AM
but there is no room to install the washer and bolt in the back of the tensioner, once its in its place.
can u do it before installing the new tensioner?
Old 05-22-2010, 06:04 AM
oxyg3ne's Avatar
no u have to install it when its in place
Ls1Mx5
08-12-2014 10:55 AM
MitchA
07-23-2010 04:51 PM
FLYOU
07-10-2008 09:16 PM
ninetyfivehp
06-16-2006 02:08 PM
Quick Reply: anyone purchase a OEM CCTL before???
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
