Anyone done much performance work to there bikes?
Old Jan 26, 2005 | 05:53 PM
stephen4785's Avatar
Default Anyone done much performance work to there bikes?
Anyone done alot of work to there bikes? Stuff like power commander,air filter, gears,cams,headwork,suspension mods, appearance mods? Just anything. If so please list what youve done, if you think it was worth it(any pics would be cool)? And would it be worth it to do some internal engine work(cams,head work,etc..) or just leave it stock?Thanks for any reply's.
Old Jan 26, 2005 | 11:07 PM
mkfosgate's Avatar
Default RE: Anyone done much performance work to there bikes?
ORIGINAL: stephen4785
Im one tooth down in the front, and lowered. You will notice a considerable difference when you go a tooth down in the front. If your dragging, you will want to lower it once you put that sprocket on. Im getting ready to put a nitrous kit, and a power commander on mine right now, so ill post up when its all said and done.
Oh yeah, sprocket and lowering is worth it if you drag, if not. I would just do sprocket, and power commander.
Old Jan 27, 2005 | 02:54 AM
Scrapyard's Avatar
Hey everyone. New to the board. I've got an F4i motor I'm working on for a project bike. Besides the usuall gearing and intake, exhaust swaps, are there any little cheap tricks ya'll have for these engines? Also, any speculation as to the gains of a big bore? When I got the engine, it had a blown head gasket. I figure if it's worth doing, now's the time to do it while it's apart. Thanks
Old Jan 27, 2005 | 10:25 PM
mkfosgate's Avatar
ORIGINAL: Scrapyard
I dont know if there is any "cheap" tricks you can do to these bikes. A stroker kit is going to cost you around 2 to 3k. I have NO idea on the displacement it would make on these engines. I would GUESS they would give you around a 20 hp gain, ROUGHLY!!! For that, you might as well put nitrous on it. But then with a big bore kit, you have that extra power, AND then you can put nitrous on it.
In just plan on doing maybe cams in mine before I go to a stroker motor.
Old Jan 28, 2005 | 01:20 AM
Scrapyard's Avatar
for 2-3k I'd rather build a big block oil cooled GSXR. I saw weisco had a big bore kit for the F4i at around $400. But if you're only get'n around 20hp with a stroker, I'll just leave it stock. Not worth it for me to put that kinda money in a 600. Thanks for the info.
Old Jan 28, 2005 | 01:35 AM
mindz's Avatar
put a big motor in your 600.....by that i mean bad *** big cc motor with 600 badges![sm=icon_rock.gif]
You'd suprise alot of busa with that one[sm=trust_me.gif]
Old Jan 28, 2005 | 10:05 AM
chainstretcher's Avatar
Admin Emeritus & MVN
$2500 -- install a turbo and crank out 220+ hp with no need to refill a stoopid bottle every 10th trip down the track.
Old Jan 28, 2005 | 08:38 PM
mkfosgate's Avatar
ORIGINAL: chainstretcher
Yeah, and have 220hp worth of trouble keeping the front wheel down. Where do you think you can get a turbo kit for 2500?
Old Jan 29, 2005 | 05:51 AM
isnt 20 hp on bike alot of power? I know car wise you can spend alot more and not get as much out of it.
Old Jan 29, 2005 | 05:57 AM
what kind of motor can I put in it? And if I put a bigger motor what kind of power can I get out of it.(im assuming a 929 or 1000)
