anybody running these turn signals?
Old Jun 6, 2006 | 09:35 AM
sics15's Avatar
Default anybody running these turn signals?
just curious about feedback/comments....ebay turn signals
Old Jun 6, 2006 | 09:46 AM
fishfryer527's Avatar
Default RE: anybody running these turn signals?
It be nice if the had factory connectors, this way if they sucked, the swap back would be easy. They look good though, don't they?
Old Jun 6, 2006 | 10:33 AM
BrianAZ's Avatar
Those are the Hotbodies Racing LED signals. A few people here have them.
Old Jun 6, 2006 | 11:35 AM
F4iPilot's Avatar
just installed them.....they look real good on my bike....fit extremely well.....the only thing is you have to put a washer on the bolt because the nut will go through the hole in the plastic
Old Jun 6, 2006 | 01:46 PM
RojerLockless's Avatar
Hotbodies turn signlas are the ownage
Old Jun 6, 2006 | 04:07 PM
jjkukla's Avatar
+1 on that. It was kinda disappointing to need the extra hardware... but if you've got some spare parts lying around it isn't THAT big of a deal. Also when I got mine the wires weren't sealed to the back side of the unit all that well so I put some more epoxy back there to add some waterproofing.
And unless you don't mind a fast blinking turn signal, you'll need to install an LED conversion kit (diode and resistor) to slow them down.
Old Jun 6, 2006 | 04:52 PM
F4iPilot's Avatar
IF YOU HAVE THE STOCK REFLECTORS THE NUTS ON THE BACK OF THEM FIT THE HOTBODIES BOLTS PERFECTLY WITH THE FACTORY BACKING OFF THE FACTORY TURNSIGNAL THEN IT WILL WORK
Old Jun 6, 2006 | 05:35 PM
jjkukla's Avatar
Yep, that is exactly what I used when I did mine. Good call F4iPilot.
Old Jun 6, 2006 | 07:11 PM
sics15's Avatar
howz the wiring? come with quick connects?
Old Jun 6, 2006 | 08:00 PM
F4iPilot's Avatar
ORIGINAL: sics15
no i dont know any flush mount that comes with quick connects....i just cut the ends off my stockers, butt connected them to the new signals and then used the connections....i took the wires with the stripes and added a butt connector and then taped them up real good.........since the solid wire is the turn signal that is what went to the red wire and green for ground to the black.
