another minor problem.....T.T
Hey guys, thanks for the help before. However, I realize
there are leaks going on throughout some area.
There is some coolant leak coming out from one of three tubes
that is tucked under the side fairing. There is a very small leak (a drop or two)
coming out from the tube, and my bike does not have any temperature changes.
I am hoping that it's not a big problem because I did put too much coolant.
But I noticed yesterday that there is some heavy oil leak happening under my
exhaust manifold, because whenever I stop, there is some smoke crawling under there.
I checked my oil gauge, but there was no reduction.
Do you know what the problem may be for both these leaks?
Help will be much appreciated!!! THANKS!!!
exhaust manifold
exhaust manifold
Now I don't want to freak you too much cause most likely it's not a blown head gasket ... but, if you start noticing a loss of power combined with a little oil leak and coolant overflow then that'd be a blown head gasket.
