Another f4i won't prime..
Hello, newbie here just bought a laid over f4i guy said it hasn't started in 2 years, and I didn't not here the fuel pump prime. So I bought it anyways for cheap. I tried to jump the fuel pump from the battery with some speaker wire nothing happen so I bought a fuel pump and swap those put everything back together and won't prime. So I bypassed the tip over sensor from the plug itself (2 outer ones together ) and the pump still won't prime. And when I turn the key over and flip my kill switch I can hear 2 relays in the back click together.
Also before I bypassed the tip over sensor my headlights worked fine, after I cut and joined the 2 outer wires together my headlights won't come on. And all the lights on my gauge cluster are lit up.
Any suggestions? Is the fuse for the pump itself? Thanks.
Welcome to the forum and the wonderful world of f4i!
For the pump to prime, the headlight must work. There is a fuse for it In the box. The circuit also goes through the kickstand switch, kill switch, and a relay.
Good luck tracing.
Good luck tracing.
there is a repair manual around here somewhere, you can diagnose your problems with that.
page 5-53, you can do a google search and find it with a quickness.
i just realized that this can help me with my problem /facepalm
example, disconnect the fuel pump black connector, turn the ignition on and measure the
voltage between the terminals brown + and green -
there should be voltage for a few seconds, if there is voltage, replace the fuel pump.
no voltage, inspect the 30 amp fuse 10amp fuse engine cut off relay, etc etc.
definitely check that shop manual out
Thank you for the support, I will keep tracking down the problem and keep you updated!
But has this happen to anyone? After you bypassed the bank angle sensor all the lights on the cluster are on and te headlight is VERY VERY dim to almost off?
Ok the myth about the headlight, i gotta call BS on. Iv started my f4i countless times with out a headlight. I have the upper subharness with ZERO HEADLIGHTS pluged in. Odds are its the bank sencer stuck. just jump it and see whats up.
you may want to verify this is safe, i was able to spray some sea foam deep creep into the throttle bodies.
don't use carb cleaner unless its for fuel injectors, that stuff will eat plastic.
so, i sprayed it into each intake and kept the throttle closed, turned the key on, hit the
engine run switch.
started the bike and opened the throttle, she revved for a quick second, verifying i had spark.
if this is a good idea, i dunno. i actually used carb cleaner at first like a fool.
just trying to be helpful but i don't know if what i suggested is ok.
engine run switch.
Bank angle is already jumped, I saw 2 ways to jump it from the 3 wire adapter itself connect the 2 outside together ir from the grey harness jump the 2 outer wires together. Which method is correct?
