Another 01-03 subframe question
Old 06-02-2009, 07:33 PM
thef4i's Avatar
Default Another 01-03 subframe question
Hi all. Anyone know what the brown spot is on the side of the subframe? Thanks.
Attached Thumbnails Another 01-03 subframe question-btf5odw-mk-kgrhgoh-d8ejlllyv52bki-8qd-_1-1-.jpg   Another 01-03 subframe question-btf5le-wk-kgrhgoh-csejllltswbbki-ydvgg-_1-1-.jpg
Old 06-02-2009, 07:42 PM
PlayfulGod's Avatar
cant tell by those pix. Have any full res pix?
Old 06-02-2009, 08:02 PM
thef4i's Avatar
Nope. I wish I did though. Any guesses?
Old 06-02-2009, 08:34 PM
sleestak's Avatar
Rust? Dent? Primer?
Old 06-02-2009, 08:52 PM
thef4i's Avatar
I asked the seller if it was rust and they responded by saying "aluminum doesn't rust".
Old 06-03-2009, 12:31 PM
florida f4i's Avatar
He is correct, that it doesn't rust, but it can corrode.
Old 06-03-2009, 02:47 PM
xjoewhitex's Avatar
Id say whatever it is it will be ok, because as said aluminum doesn't rust. But it could be a form of surface rust maybe I don't know. But it could be sanded off, im sure your not keeping it black right?
Old 06-03-2009, 08:56 PM
thef4i's Avatar
I was planning on keeping it black... but now im not so sure lol.
If its just a surface / cosmetic thing I dont mind, but I just wanted to know if it could be unsafe. I remember someone telling me that a bad subframe will come out under you in a hard turn.
Im actually thinking of purchasing a subframe from a cbrf member but for a starting bid of $50... I wanted to get as much info on it as possible.
Old 06-03-2009, 10:55 PM
cman9toes's Avatar
Sand on it, if it is superfical, then it wont take much to be gone, but if you have grind it off, then I would be concerned.
Old 06-03-2009, 11:29 PM
Have you purchased said subframe yet?
If so, and you are feeling frisky, give this a shot -
http://www.ehow.com/how_14455_remove...-aluminum.html
Quick Reply: Another 01-03 subframe question
