Air box
Old Feb 20, 2013 | 04:48 AM
zbake's Avatar
Default Air box
I just got a 2001 f4i and I am trying to change out the cct... Can anyone tell me the preferred method for removing the air box? I'm not sure how to disconnect the map sensor? From the air box...
Old Feb 20, 2013 | 06:11 AM
RudyGT's Avatar
if the upper cowl is off the easiest way is to disconnect the snorkels at the mid way point, just stick your finger in at the bottom and pop them out.
i think you can disconnect the map sensor with it still connected to the throttle bodies, it is probably just stuck on there.
you have a little play on everything so you can unscrew it and lift and try again. its the same as any connector, squeeze the right spot and pull.
Old Feb 20, 2013 | 06:23 AM
rd91si's Avatar
I changed mine by just lifting the tank and removing the right fairing. It's tight but I have
big hands and had no problem, you need the right tools.
Old Feb 20, 2013 | 09:23 AM
zbake's Avatar
Nice! What tools do I need? A magic wand?
Old Feb 20, 2013 | 10:02 AM
mnguyen84's Avatar
your brain?
Old Feb 20, 2013 | 10:14 AM
bamato's Avatar
A 1/4" drive ratchet, a couple extensions, and a few wobbly's did the trick for me. No need to remove the air box.
Old Feb 20, 2013 | 10:47 AM
zbake's Avatar
Cool thanks for the input
Old Feb 20, 2013 | 05:00 PM
Kopi Ko's Avatar
I rather unscrew the airbox rather than squeezing my big hands into that tiny spot trying to unscrew the sensor from the bottom. Take less time and effort IMHO.
Old Feb 20, 2013 | 08:31 PM
Scott91370's Avatar
I tried one day for two freakin' hours and could not get mine out. Could never get the bit to bite enough, it just kept slipping.
There is a sticky with a lot of good info and this page too:
F4i CCT Swap - pictures/directions - BARF - Bay Area Riders Forum
