Adjustment Tech lowering links
Old Jun 2, 2006 | 03:30 AM
skeelo's Avatar
Default Adjustment Tech lowering links
http://www.adjustmenttech.com/images.../adjusters.htm
Hi! I just pick up a used set of these "height adjusters". The original owner had it installed by a shop so no install instructions. Anybody using this kit? Any tips on install?
Thanks!
Old Jun 4, 2006 | 05:49 PM
skeelo's Avatar
Default RE: Adjustment Tech lowering links
Well, I installed it yesterday. This link is awesome. Height adjustable without having to remove it, even with someone sitting on the bike.
Old Jun 4, 2006 | 07:21 PM
ozmac's Avatar
how much to do the install ? was it done by dealer or in the "driveway" just wondering if ti is a do it yourself job or not
thanks
OZ
Old Jun 4, 2006 | 09:53 PM
skeelo's Avatar
Me and a buddy installed it in my garage. No cherry picker needed. Very easy job. I used a piece of wood between the reat tire and tail so I can remove the stock link. I had my friend to shift the tail up and down so I could easily remove the the top bolt. Once the top bolt was removed the bottom one slid right out. I set the lowering link so it was a little longer than stock then bolt it on. Once bolted on, set the acquired height buy turning the big locknut or lower the front first then go back to the rear set final height, which is what we did. That's it.
ORIGINAL: ozmac
thanks
OZ
Borowicz_Cbr600f1
Jul 12, 2012 04:54 PM
maark
May 28, 2010 07:43 PM
Eliteedge0788
Mar 28, 2010 04:34 PM
grazi
Mar 31, 2008 09:40 PM
thrush06
Jul 3, 2007 07:04 AM
