520 vs 525
Old Jan 18, 2006 | 01:12 AM
bikesnjeeps's Avatar
Default 520 vs 525
I am considering the 520 conversion on my 04 F4i. Does the 520 chain wear any faster or slower than the stock 525? Is it any weaker? I know it is lighter, but why didn't the factory go with it? also I am thinking about going -1+2. Or maybe just -1. Opinions, thoughts?
Old Jan 18, 2006 | 01:36 AM
thirdgenlxi's Avatar
Ironmang
Default RE: 520 vs 525
Well I've only had my 520 on for about a month or so, so it hasn't really had a chance to wear of any significance yet. I did have to adjust it just a hair the other night cuz it was a little loose, but I figure since it's new it's gonna stretch a little bit initially regardless. A friend of mine used to have a Busa (has an RC-51 now), and it had the 520 chain (originally 530), and he said it stretched the chain out pretty quick. A Busa makes ALOT of power though, much more than an F4i, so might be alright on ours. Guess I'll wait and see too!
Old Jan 18, 2006 | 01:48 AM
IrideHONDA's Avatar
if you go -1 in front you can keep the stock 525 chain to see how you like it. it's like a $30 trial investment. that's what i'm about to do, but it depends on the application. stuntin it out, go 520 with -1/+3. want more power out of the corners, try -1 w/525.
Old Jan 18, 2006 | 12:47 PM
Tahoe SC's Avatar
no mang...if you stunting, stick with stock and then the -1/+2 or 3...if you racing and canyon riding, etc...but hardcore, then go with the 520 and +3 (is about -1). you don't need the decreased weight of a 520 when you're stunting.
i say +3 for a 520, in fact any chain as it'll wear better than a -1. make sure you change both chain and sprockets or else the older stuff will make the newer stuff wear quicker.
as far as strength, they are pretty strong, depending on the company. i will only do DID cause they hardcore. i've had bad experiences with others...EK/RK.
520s are rated up to 750 and at times 1K, but busa is a beast...should use like 585 if they have them.
Old Jan 18, 2006 | 04:24 PM
not really into stunting that much, only once in a while do I bring her up on one. I prefer canyon riding and am really just looking for that little extra pull out of the twisties. So a 525 +3 wouldnt hurt me that much, and I would be able to swap in the stock 46 for long freeway rides where economy is more important.
Old Jan 18, 2006 | 05:00 PM
Tahoe SC's Avatar
yo mang...i currently have -1 up front with 525...when i swapped gears, my MPG went down like 2 or 3...went from crap to $HIT!...33 now 31...but it pulls good. you'll need to get used to the RPM when on freeway though.
T
Old Jan 18, 2006 | 07:03 PM
doncollins's Avatar
Retired Administrator
I second what tahoe said. I have the same setup and I'm about to go to a -2 in the front. Wonder how my mpg will be then. [:@]
Old Jan 19, 2006 | 12:31 PM
Tahoe SC's Avatar
not to scare the mang but mines dropped from the 38/36 sometimes 40 to 33 from the full system, then another 2 from the gear swap.
don you gots the RR, it's got that crazy dual injector action right? chill and you're ok...hammer it and you'll be gassing up from light to light! buahhhahhah...
Old Jan 19, 2006 | 01:54 PM
doncollins's Avatar
Right... that's what I'm saying. 8 injectors can spray a lot of fuel if need be. The high 40's and 50 mph is very, very, very rare. Only when I'm doing a group ride and basically riding in parade formation. Not much fun, but you go along with the group and have a little fun after the ride.
Old Jan 19, 2006 | 01:58 PM
Right on, stock 525 chain it is, with a +3 on the rear and I will only lose a little on fuel economy. Works for me, it would still get 2x the fuel milage of my car, and like 3-4x the milage of my truck. [sm=lildevil.gif]
