2nd gear issues
Old May 10, 2009 | 02:31 AM
hockey guy's Avatar
Default 2nd gear issues
I have an extremely hard time shifting from 1st to 2nd gear when my bike is up to temp... When I first start the bike and it is cool and warming up, the issue does not exist.
When I am having this problem, I will go to put it into 2nd and it will only go into neutral and I have to try over and over until it finally works. What could this be? My buddy was thinking the shift fork and then I just told him about how it worked when it was cool. If it is the shift fork, can it be replaced if we take the oil pan off?
Old May 10, 2009 | 12:30 PM
drunkinmist's Avatar
Sprocket Hauler and Savior
I am having the same problem with my 02 f4i. I have to slow down to 25 before i can upshift into second or come to a complete stop and downshift and then upshift. Any answers would be nice.
Old May 11, 2009 | 02:15 AM
hockey guy's Avatar
The issue seems to be getting better with the 2nd gear. I did an oil change and for some reason the issue is not as bad. It still happens from time to time, but not nearly as bad as before...
Old May 11, 2009 | 10:48 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Although blipping the throttle is primarily used for down shifting, I have found it useful in smoothing out upshifts as well. Initially I had issues upshifting and felt that the gearbox felt very clunky. Over time I've discovered that modulating the throttle has improved shifting on this bike. On occassion, I will miss the 1st to 2nd shift, ending up in neutral. Oddly, I find shifting from 1st to 2nd easier at higher RPM, vs. lower ones.
Another thing to consider may be to lower the shift pedal a bit (it is adjustable), so that your foot makes better contact with it. Also, make sure you are fully engaging the clutch before shifting.
I'll totally agree with the oil change; it feels so nice when it's fresh
Old May 11, 2009 | 11:01 AM
I have adjusted and oil changed but have the most problems after 7 rpm between 1 and 2 gear. Once it gets into N i won't go back into either 1st or 2nd.
Old May 12, 2009 | 01:24 AM
thef4i's Avatar
I had the same problem but making sure the clutch is pulled all the way in and shifting all the way down/up helped a lot. My tacoma does the same thing. After about 3500 rpm/20+ miles i cant shift it back into first gear. If i try itll makes that grinding sound/feeling.
Old May 12, 2009 | 01:58 AM
boredandstroked's Avatar
Worn shift forks and you have to pull the trans apart to replace.
Old May 12, 2009 | 08:51 PM
hockey guy's Avatar
So the issue has gone away. I adjusted the shifter to have more travel upwards when shifting and it shifts great. I'm guess they previous owner messed with it too much, the lever was hitting the metal piece that the peg is mounted too. I now have an excellent running F4i
Old May 12, 2009 | 08:56 PM
supersnake83's Avatar
Glad to hear that you got it fixed/working better. Could you post some directions for what you did. I am sure that someone else will have a similar issue and this can be very helpful to them. I have a similar issue and will see if this fixes my problem too.
Thanks.
P.s.
If you can add a picture too, that would be great, but no biggie if you can't.
Old May 12, 2009 | 11:01 PM
thef4i's Avatar
+1 !!!
