2012 Winter To-Do Lists
Figured all of us could use a place to keep a list of what we plan on doing to our bikes while they are stored away in the winter.
As I have hit 12k miles on the odometer I have a couple crucial things to be done... My running list: Replace oem air filter with K&N air filter Replace brake fluid Replace coolant Powdercoat rearsets Check spark plugs Replace chain, & possibly sprockets |
I have no work planned for my bikes this winter, but my advice to everybody working on their bike in the winter is to work SLOW. Last year I spread out my work long enough to just about hold me over until it was riding season again.
Gonna do the run-out on the valves, their definetly due at the 20k I've got on the
odometer. Re-build the seat, I log 100-120 miles and my butt hurts. Start a serious hunt for a set of bars that will put me where I need to be. It's time for the serious paint for my little beastie, as well. I threw a rattle-can at her when she first came home, a year ago. It's time for the pearl grey/white with black tiger strips on the uppers and nose. Black (maybe a white pinstrip) for the lowers and side/tail. That should keep me busy during the days it's too ugly to ride. Ern |
New pipe
Pciii + dyno tune New plugs New battery 2-4 new led strips New front tire |
Change the chain and sprockets, maybe throw in a speedo healer
Oil change Replace brake fluid Fix front turn signals and double check other wiring I hastily put together |
New fairings
Manual CCTL Bleed Brakes again New Brake and clutch lever New battery possibly That may be it |
Make it mine
new chain & sprockets
front turn signals new rear farings/undertail remove 12o'clock bar new rear turn signals touch up the crank case where my brother dragged it through the gravel adjust throttle and clutch check/replace fluids would like to replace levers too new headlight that actually provides light at night |
Honda:
Tires Oil Change Kawasaki: Tires Dialed suspension -1 front sprocket Oil change Not much overall, and I'll only buy the parts during the winter. Work won't start until spring. |
did the oil change yesterday.
- undertail - new windscreen already got the parts, just not sure if i can actually do it myself lol.. |
-Oil Change
-New Plugs -New Battery(how can you tell if its old no build date its the jap one) -Trying to figure out to get maybe oem weights for handle bards to keep down vibration? |
