2006 Oil change step by step
Old Jun 29, 2012 | 05:27 PM
Budweis0r's Avatar
Registered Users
Default 2006 Oil change step by step
Hello, I have yet to perform my own oil change on my bike and was hoping that someone could post or if there is one a complete step by step guide on how to change the oil. Also, what are some people's recommended oil types.
Old Jun 29, 2012 | 05:50 PM
boredandstroked's Avatar
1- stop riding bike.
2- put drain pan under bike.
3- remove oil plug.
4- replace oil plug.
5-remove oil filter
6- replace oil filter.
7- refill oil.
You don't need to remove any fairings or use a rear stand.
Old Jun 29, 2012 | 06:00 PM
Turbulenz's Avatar
Official Welcome Crew
I remove the left hand side fairing so nothing is in the way, and then I put some alum foil under the filter on the header so that anything that runs down will go through the foil like a funnel and drain into the pan.
I use Rotella T conventional oil, but for my f4i I am going to try out their synthetic.
Old Jun 29, 2012 | 06:06 PM
Kuroshio's Avatar
Ororo likes Mobil 1 Racing 4t motorcycle oil. Forgot to tell you that's what I've changed the oil with on her
Old Jun 29, 2012 | 06:11 PM
Turbulenz's Avatar
If that's what she is used to, I had better not change her diet.. lol
Old Jun 29, 2012 | 06:36 PM
Budweis0r's Avatar
Registered Users
Ok I am going to check autozone for Mobil 1 Racing 4t motorcycle oil im assuming they have it there. Also, how many quarts will I need?
Old Jun 29, 2012 | 06:51 PM
74demon's Avatar
Get 4 qts. You will have some left over.
Don't be surprised if auto zone doesn't have it. They don't carry that much motorcycle stuff. You will probably need to go to a motorcycle parts store.
Old Jun 29, 2012 | 06:52 PM
RudyGT's Avatar
4 quarts, the bike takes 3.5 quarts after a oil filter change, don't over fill it. make sure you get oil for motorcycles because of our wet clutches it is common practice to use oil specially designed for it.
Old Jun 29, 2012 | 07:46 PM
Kuroshio's Avatar
I use Mobil 1 out of preference. I liked the clutch response after switching on the F3 from Rotella. Pep boys carries it here
Old Jun 29, 2012 | 08:51 PM
Budweis0r's Avatar
Registered Users
Thanks a lot guys.. I almost forgot what kind/where oil filter do I switch it out with?
