2004 CBR won't run
Old Feb 23, 2010 | 01:25 AM
andrewswe's Avatar
Default 2004 CBR won't run
Hi guys,
I just bought a damaged 2004 CBR 600, it is missing the clocks.
It will turn over but won't run. Does it need clocks to run?
The fuel pup doesn't run up when you turn the key on.
All help much appreciated.
A.
Old Feb 23, 2010 | 01:55 AM
letsride's Avatar
Does it have the tip over sensor in place?
Old Feb 23, 2010 | 01:59 AM
DDMGraphix's Avatar
tip over sensor is in the front.. If you remove the windscreen you will find the sensor. You can use small wire you can jump the tip over sensor and the fuel pump shoud engage. Also there are several other things, Broken wires so check your harness (last resort), blown fuses... Hope this helps.. One last thing which is funny but had this issues. Inside your ignition is a fuse. If it is blow bike will get power but fuel pump will not engage..
Old Feb 23, 2010 | 02:29 AM
ssweetbro's Avatar
+1 on tip over sensor
Old Feb 23, 2010 | 08:52 AM
skoobydoobie's Avatar
Its not a fuse, its a diode.
Old Feb 23, 2010 | 11:49 AM
shkapars's Avatar
Originally Posted by andrewswe
Hi guys,
A.
it should be angle sensor as mentioned above or if it is EU model (I saw SWE in your name) could be HISS. To check angle sensor, connect green and red wire near to sensor, to check HISS - get from some friend HISS from any Honda in working order and replace.
Old Feb 23, 2010 | 12:08 PM
DDMGraphix's Avatar
Thanks Skoobie for the correction.
Old Feb 25, 2010 | 12:15 AM
andrewswe's Avatar
Default Thanks
Cheers guys, I assume the tip over sensor has gone, any idea where it plugs into the loom as the clock loom is missing?
Andy
Old Feb 25, 2010 | 02:42 AM
shkapars's Avatar
three point socket, wires - green, white/black, red/white
or find in front big sockets red/white wire and connect it to green
Old Feb 25, 2010 | 08:30 AM
ars1986's Avatar
just by pass the tip over sensor, there is a how to on stuntlife.com. it beats buying a new one.
