2002 Honda CBR F4i 600 chain wobble HELP!!
Old Mar 19, 2012 | 07:47 PM
maclark014's Avatar
Registered Users
Default 2002 Honda CBR F4i 600 chain wobble HELP!!
Every time I tightened my chain, it would get loose again. I put it up on the stand and found the chain to wobble. It gets tight and then powers through the tension. Any ideas on whats causing this?
I posted a video on Youtube:
2002 Honda CBR F4i 600 chain wobble - YouTube
Old Mar 19, 2012 | 08:22 PM
74demon's Avatar
Check for a link thats binding. Thats a sign that the chain needs replacing.
Old Mar 19, 2012 | 08:24 PM
maclark014's Avatar
Registered Users
I ordered a new chain and sprockets. I hope that will fix it.
Old Mar 19, 2012 | 11:29 PM
Michael of Burien's Avatar
Also check that the rear wheel and sprocket are in alignment with the front tire and drive sprocket. A quick google found this.
Wheel Alignment: Avoiding the Crab Walk [Archive] - Suzuki GSX-R Motorcycle Forums Gixxer.com
Old Mar 20, 2012 | 06:53 AM
jeffjones's Avatar
+1
With your bike on the rear stand turn the rear tire about a 1/4 or 1/8th turn and measure the slack, If it is not the same for every measurement then you have a tight spot and the chain needs to be replaced.
Also it looked like you were near the end of that chains life as it is.
Old Mar 20, 2012 | 09:30 AM
maclark014's Avatar
Registered Users
That's go to be what it is. Is it ok to ride on until I get the new chain and sprocket kit on it?
Old Mar 20, 2012 | 10:19 AM
gotcbr's Avatar
That is a very loose chain. If you can wait til you change it out b/f riding it again, that would be a wise decision. I've seen loose chains violently jump off sprockets & not only lock up/damage the bike but also injure riders. It isn't pretty in either instance. Err on the safe side & wait til your new chain & sprocket install b/f riding again.
Justin952
Feb 16, 2012 11:14 PM
helluvani99a
Oct 19, 2008 01:38 PM
helluvani99a
Oct 6, 2008 12:21 PM
blaine6070
Jun 25, 2006 06:37 PM
