2002 F4i HID problem !!! HELP
Old 04-10-2009, 09:20 PM
714 SoCaL F4i's Avatar
Default 2002 F4i HID problem !!! HELP
Whats UP all, Just wondering anyone got any info , on why I Keep blowing my headlight 10 amp fuse , when i start my bike up , I just put a low beam HID kit in , but it seems it blows the fuse every other time when I start tthe bike up ??????
Is there a possible , short, open in the circuit, Anyone got any cluess, let me know , need a solution
THanks ALL!!!!!!!
Old 04-10-2009, 10:26 PM
Stephens's Avatar
So does the headlight come on at all? If you blow a fuse before it ever comes on, it is your wires are probably wired wrong. You just need to change the wires to the headlight and that should fix it. Do you have a voltmeter, then you can check to see which wire is your hot wire.
Old 04-10-2009, 11:46 PM
Yeah they come on, as soon as i start the bike , They blow the fuse, They are on , when I turn the key its just when I start it it blows the fuse then they go out
Old 04-11-2009, 03:30 AM
Aken's Avatar
July 2008 ROTM
The ballast is probably pulling too much juice when it restarts (meaning when the light turns off when the ignition button is pushed). If you're using a 55w HID bulb/ballast, then that is probably your problem.
Otherwise can't say for sure. I've run two different sets of HIDs on my bike and never blown a fuse.
Old 04-13-2009, 10:24 AM
MidnightG35X's Avatar
I would think it is wired wrong. The standard bulbs are 55W also, so a 55W HID bulb/ballast should be the same.
Old 04-13-2009, 04:40 PM
Rotory2F4i's Avatar
Yea, somethin sounds wrong. I have high/low beam HID running off the 10amp fuse and have never blown it. Maybe its pullin to many amps, or you have a lesser quality ballast. If you are sure that it isnt wired wrong, try a 15, wouldnt go any higher than that, for I would fear you could damge wires.
Old 04-13-2009, 08:01 PM
Aken's Avatar
July 2008 ROTM
No - a 55w HID will take a LOT more power on the initial ignition than a standard bulb, which would easily blow the fuse.
Also if it were wired wrong, it would blow the fuse anytime the bulb tried to ignite, not just when the bike is starting (IE it would blow once the key was turned on).
Sounds like a crappy ballast...
Old 04-13-2009, 11:40 PM
Stephens's Avatar
Here's an idea, you have two ballasts. Use the other ballast and test it to see if it is the ballast that is causing it. You only need one at a time to test it. If its bad, send it back.
Old 04-14-2009, 02:02 AM
DarkJuic3b0x's Avatar
whew, glad I looked around on the forums before i purchased my set of HID conversion kit. http://starrotors.com/bulbs/, im looking to get the 8000K iceberg blue from there.
hopefully I don't get any blown fuses
Old 04-14-2009, 04:18 AM
97BlownSaleen's Avatar
if it works fine and is only on start up...try wiring in a switch and turn on your lights after you start up the bike...the initial inrush current might be the problem so if you have the bike already running it has little more current flow and might be able to handle the inrush
Quick Reply: 2002 F4i HID problem !!! HELP
