2002 CBR F4I - Doesn't wanna go past 9 or 10k Rpm
Hi, I have a 02 F4i and I’m having the issue where my bike doesn’t wanna go past 9 or 10 k without sounding like it’s gonna blow up. I’ve checked all hoses and fuel lines and nothing seems to be kinked. What else would it be? I run at 7k rpms going 55. That’s wild high. I did do a sprocket set change, but it shouldn’t affect it that much, it won’t even hit the power band. TIA!
yes, im using all 6. I can’t remember what sizes I put on, all I know is it produces more torque and less top speed. Both sprockets got changed in size. But that shouldn’t make it run at 7k and 85k on the highway.
yes, I changed the sprocket ratio. But this would make it so the bike never hits the power band? It barely makes it to 10k RPMS. Let alone all the way to 15 or 16.
is there anyway my valves could be going bad? Bike has 24,000 miles and a shorty exhaust on it.
I'm confused.
Will it not run past 10k in any gear?
OR
Does going 75mph make it get to 10k rpm and you don't want to run it any higher?
It won't go to 15 or 16 unless you've removed the limiter.
And we do need a count on the teeth for both sprockets. This will give final gear ratio and tell us what the top end will be as well as speed for any given RPM.
OR
The following users liked this post:
Zac May (09-28-2024)
Everything that the guys have said is spot on.
One thing to keep in mind is that these bikes are set up in a specific way to provide an even, broad range of power across the spectrum. When we modify that setup, we change the way the bike can perform across that same spectrum.
Think of a triangle that is even across all three sides. If you take and stretch one of the points of that triangle making it longer, you now have sides that are no longer of equal length. It's still a triangle but has different properties in every way. In this conversation, changing the sprockets is changing the point of a triangle, You get better performance in one area, but you sacrifice a different area. Your triangle has changed shape.
I'm confused.
OR
OR
