2 flash fi code
Old Dec 26, 2012 | 03:42 PM
chute's Avatar
Default 2 flash fi code
So ive been battling this weird problem the last 2 months. I was taking my airbox off to get to the cct and decided after I took it off that I didnt want to deal with changing it and took it to the shop the next day. I pit it all back together but since then if its cold outside or it rains and my bike is outside. I get really low idle for about 10 seconds then bumbs up to normal idle. Then 2 flashes, it didnt happen for almost a month then Last night happened again. I took the airbox off again and undid the map sensor and redid all the conections on friday. It rained last night and happened again. My gas mileage has gone to 120 a tank the last few months since then. Is there anythijg else I shoupd do? Why is it only happening very little and only when its copd.
Old Dec 26, 2012 | 04:50 PM
RudyGT's Avatar
on the left side of your airbox there is your map sensor, there is a hose that plugs into that as well as the wire connector. right in the bottom.
there are 5 hoses that go into your airbox, and 2 sets of wires.
Old Dec 26, 2012 | 10:25 PM
chute's Avatar
I know where the map sensor is, I'm trying to find out if there is anything else I should check, the hoses are fine, I've checked all connections and blew them out to make sure there was no leaks or anything in there.
Old Dec 27, 2012 | 01:13 AM
stlcbr600f4_newb's Avatar
check all your vac hoses the sensor may be bad
Old Dec 28, 2012 | 07:44 PM
rd91si's Avatar
Under the seat there is a 2 wire plug for checking codes, jump the wires turn on the key
to retrieve the codes.
Old Nov 10, 2013 | 07:33 PM
GK45011's Avatar
Default jumpig wires
Does anyone have a picture of this plug? If I simply turn the key (not starting the engine) I am getting a repeating two long flash, followed by 3 short flashes. Is this the code? I haven't jumped the wires so I don't know if this code is correct.
If this is the correct code, what does it mean?
Thanks for any help,
Gary
Old Nov 10, 2013 | 08:07 PM
Kopi Ko's Avatar
Gary
23 is faulty oxygen sensor heating element
Old Nov 10, 2013 | 08:53 PM
GK45011's Avatar
I am running a gpstyle short exhaust just past the 02 sensor. Did the extra heat toast the 02 sensor? Is the heating element different than the actual 02 sensor?
Can I use a 02 eliminator with out pcIII? to solve this issue, or will I harm something else? I am new to the CBR so any help is appreciated.
Gary
drunkinmist
May 14, 2009 04:28 PM
chestnut1011
Sep 16, 2008 07:59 PM
andrewsi
May 12, 2008 09:43 PM
linkandcuff
Mar 4, 2007 10:23 AM
NINE2NINE
Jan 31, 2006 10:05 PM
