1000....
Old 09-20-2007, 10:15 PM
Default RE: 1000....
ORIGINAL: firemanron
wow. I never thought this subject would get this much attention.
look what you started firemanron... j/k i'm pretty sure there's no bad blood. they both probably just having a little fun w/ this @ work.
  #52
Old 09-20-2007, 10:21 PM
ORIGINAL: oodayvidoo
werd. The CAD i got from Japan was **** so from noon on i had **** to do and since i don't get off till 6pm i had a whole lotta time to waste Gotta love R&D[8D]
  #53
Old 09-20-2007, 10:52 PM
dondi's Avatar
I just wanted to be part of this thread that turned out so weird.
PS: firemanron, The advice you received earlier (before things went to ****) about getting your suspension setup for your weight is something worth considering. I would guess that you are outside the "normal" weight parameters that Honda engineered the F4isuspension to account for. Heck, I feel like I'm outside the parameters at 190 and I've got the rear shock set up at 6 out of 7.
What you really need is a shock rebuilt or at least resprung for our weight ranges. Forks too of course. I think if you did that it would help a lot.
Ok, it's about time for some more off-topic weirdness...[:@]
  #54
Old 09-21-2007, 06:33 AM
fishfryer527's Avatar
while i wasted time at work
That's great.
  #55
Old 09-21-2007, 10:32 AM
Tahoe SC's Avatar
yooooo....you can't get the stock shock to work with you if you're like way up there in weight...it only goes to about 150...
cranking the preload settings may feel 'better'...but the spring rate is still the same! the spring just 'moves less' for lack of better words, but the rate is still the same!?!?!?
getting suspension set up to your weight getsvery expensive if you have 3 meals/day and weigh more than 150...because you need suspension work, not just adjustment.
PS...university of phoenix MBAs, etc. are still valid degrees nonetheless.
  #56
Old 09-21-2007, 12:15 PM
dondi's Avatar
I figured it was low; didn't realize it was that bad.
I do understand that, thanks.
Yeah, I looked into it. It's something I'm going to do at some point, maybe even this winter. Just need to make sure SWMBO get's with the progam.
Without spending any money my options are limited to fiddling with the spring rate and damping
yes
  #57
Old 09-21-2007, 02:05 PM
ORIGINAL: Tahoe SC
oh shnaps! just when you think it's getting back on topic... here it comes! love it... just love it... you guys are f*cking awesome
  #58
Old 09-21-2007, 02:47 PM
150? That is insane, I've taken ****s that are 150. What is a grown man supposed to ride on?
  #59
Old 09-21-2007, 04:30 PM
firemanron's Avatar
I totally disagree with the 150 mph only. Like I said I do weight close to 240 and I have gotten my F4i to 156 mph with no problem and that wasnt even close to redline, somewhere around 9 or 10,000 I believe.
  #60
Old 09-21-2007, 04:35 PM
Tahoe SC's Avatar
whoa...we're talking suspension here, and 150 lbs and not mph...
tahoe doesn't discuss squid speed issues.
to save money, i know some shops that will respring and revalve the stock rear shock...the front you'll at the ver least need to swap springs.
Quick Reply: 1000....
