-1 in the front
Old Apr 11, 2007 | 01:34 PM
Candymanmo06F4I's Avatar
Default -1 in the front
Hey i remember a few days ago a person on here was told just to do a -1 in the front for the sprocket and was suppose to be a cheap fix to get faster acceleration and but a loss of top speed. I also did a search and noticed that if u do that front sprocket it messes with the spedo and its off from that point on. Also do you have to change the length of the chain or the chain it self if u just want to do a front sprocket change to -1. I dont think i want to do the +2 in the rear just yet and hear from the writing its not recommended unless you are running on the track which i wont be doing anytime soon.
Any help would be appreciated.
Also if you have done just the -1 was it worth it?
Old Apr 11, 2007 | 01:37 PM
Default RE: -1 in the front
Also about how much are te spedo healers, heard that some people use those on this site and do they actually work.
Old Apr 11, 2007 | 02:45 PM
BillytheKid's Avatar
i can help you on this one.
I have a -1 in front vortex sprockets with 520 chain. The acceleration is reasonably better. Another thing - you wont lose anything on your top end, at most you can add something. Why? On the highways when we are driving at full blast, the engine can express its torque better with a smaller front sprocket. My rev limiter used to kick in 6th gear withe -1 sprocket, something which NEVER happened with the stock front sprocket. The downside is that it consumes more fuel + more engine wear. Another downside is that you will reach 15K revsfaster and you have to be careful. I possibly redline each gear, and when i changedto a -1sprocket i used to fall in the rev limiter trap cos it engages sooner. I would never go back to the stock gearing unless i am going for long trips.
Old Apr 11, 2007 | 03:06 PM
was it an easy installation. or did u hvae an issue doing it.
Old Apr 11, 2007 | 03:10 PM
i did it myself with a torque wrench. I had replaced chain and both sprockets so i dont know if replacing the front sprocket alone entails removing thechain as well but i dont think so. Should be a 15 min job if you have the right tools especially with a pneumatic drill.
Old Apr 11, 2007 | 03:20 PM
ninetyfivehp's Avatar
i'm thinkin of going -1/+2 as well. don't care about the loss of top end. my bike rarely sees 100 much less 157.some more grunt out of the corners would be nice. can this gearing be achieved using the stock chain? and stil be able to set the proper amount of chain slack? thanks
Old Apr 11, 2007 | 03:34 PM
Jaybird180's Avatar
Good question on the slack.
Is a pneumatic drill really necessary? Does it take that much force to break the seal at the countershaft?
Old Apr 11, 2007 | 04:01 PM
naw, you should be able to just put the bike in first gear. it's only 40 lbs/ft i think. unless your quite the lady
Old Apr 11, 2007 | 04:49 PM
dreadf4i600's Avatar
so if you go -1 in the front its not true you will loose some on your top speed
Old Apr 11, 2007 | 04:57 PM
Jaybird180's Avatar
Probably a negligible amount.
