06 Fender delete pics??
I'm looking to make my own fender delete because I work at a metal fab shop and I need a lunch project! I was wondering if any one had any good pictures of them from inside the trunk and under the tail just so I can get a good idea of how they are mounted and how they did the lock.
Thanks in advance! Nick |
RE: 06 Fender delete pics??
i took a angle grinder and did it the cheap way
Did you relocated the bolts for the tag or did you just cut it right below it.
Rocfrog... I have a Hotbodies undertail and i had to relocate the trunk lock, cut the fender, ect... here is a link to the instructions to do so...
http://www.hotbodiesracing.com/instr...ctions(05).pdf |
I was looking for something along the lines of this But I don't want to use the stock turn signals!
http://imagescommerce.bcentral.com/m...5356/1H603.jpg I know this is a Competition Werkes Fender Eliminator Kit , but what I need to know is how they mounted it and if anything needs to be cut out to install it? Nick |
you will need to cut the fender like they have illistrated in the link i sent to you for the Hotbodies undertail...i had a homemadeundertail similar to that one before the H/B and i had to attatch it to the part of the fender/battery tray where the tool kit was kept...
this is along the same lines. I just raised mine up. drilled the upper left hole big enough for
my key. used led bolts for plate light and followed the led foot peg post in the how to. plus integrated light. https://cbrforum.com/m_189145/tm.htm |
ORIGINAL: vasta101 you will need to cut the fender like they have illistrated in the link i sent to you for the Hotbodies undertail...i had a homemadeundertail similar to that one before the H/B and i had to attatch it to the part of the fender/battery tray where the tool kit was kept... ORIGINAL: tslayer this is along the same lines. I just raised mine up. drilled the upper left hole big enough for my key. used led bolts for plate light and followed the led foot peg post in the how to. plus integrated light. https://cbrforum.com/m_189145/tm.htm Nick |
