06 f4i 600 wont power
i get power to the guages but when i click the switch i get nothing when i bypass the bank angle sensor and it shows up on the gauges and when i hit the left blinker i get the high headlight anybody could u help please
I had a similar problem. Are your fuel injectors priming when you turn the key? And will your engine turn over at all when you press the power button?
06 f4i
no nothing no clicks just the guages
maybe the fuses? maybe a short?
Has anyone messed with your wiring? Or is it all factory?
Is your kill switch in the on position? Try bypassing that switch too, and kickstand switch. |
Yeah when I was having this problem, a wire had come loose inside of my kill switch and I had to re solder it and it was all working great again after that. It affected the FI and the ability to turn over. So thats my guess of what your problem is
Check your front harness connection between the bike and your headlights , it's a small connector that has a small tendency to burn. Disconnect and just inspect it, it's pretty easy to see if it's burned
Originally Posted by Slick 6
(Post 1005721)
06 f4i wont power
i checked the wires they look okay isnt there a neutral safety switch could that be it ??? an where is it
check your engine stop/ fuel cut relays...
