02 F4i vibrations
Old Jan 7, 2012 | 07:51 PM
02TrickFlowGT's Avatar
Default 02 F4i vibrations
hey guys just wondering a couple of things? I used to have a f4 and it was a pretty smooth ride, i got a f4i last week and it feels like there are more vibrations than i remember, any one els noticed this ? its a good smooth riding bike otherwise but it just feels like in the foot pegs I can feel alot of vibration, thanks!
Old Jan 7, 2012 | 11:18 PM
OZZY_F4's Avatar
yeah i get a fair bit both through the pegs and grips.
Old Jan 8, 2012 | 07:42 PM
is it more around 5500-6000 rpm and up? I can start to feeel it around 5k 5500
Old Jan 9, 2012 | 07:01 AM
vr6ptstyly's Avatar
I experience this too, I investigated, then after hear others opinions, I wrote it off as the nature of the beast. Don't really worry too much about it, but I wish I could do something about it, its not excatly inspiring at higher speeds.
Old Jan 9, 2012 | 07:37 AM
DonnyBrago's Avatar
Have you got the standard bar ends in it or some weightless POS chinese ebay specials?
The weight helps dampen vibration. Other than that your wheel could be unbalanced or you could be gripping too tight.
Old Jan 9, 2012 | 12:11 PM
with exception of the exhaust its all stock, but how much do those ends help? i got a buddy who rides with them but I really wasnt too sure about it, his weigh something like 5lbs or some crazy ****
Old Jan 9, 2012 | 02:18 PM
i also get a lot of vibration when in neutral i let the clutch out, as soon as i pull it in i can feel a difference, tranny problems or is this also a common problem? my F3 did the same thing
Old Jan 10, 2012 | 04:03 AM
OZZY_F4's Avatar
yeah i got the cheapo weights, still no where near as heavy as the factory ones, i lost the factory ones when i layed her out. the vibrations dont really worry me much.
back on the problem when your travelling along and pop the trans into neautral essentialy would be no different to free reving the bike on its stand, maybe try that and see if the vibrations the same. not quite sure if anything else would cause that type of vibration but should rule everything else out tho, if it is the same.
hope this is alittle helpful
Old Jan 10, 2012 | 09:09 PM
sparkman's Avatar
Obviously, I can't say with any certainty that there's nothing wrong with your tranny,, but it sounds normal to me. Both of the f4i's I've had/have did the same thing you describe.
Here's one I don't understand: When at idle, in gear with clutch pulled in, bike stationary, (like waiting for red light to change), the vibrations change significantly depending on whether or not the front brake is applied. Both my f4i's have done this.
Old Jan 10, 2012 | 09:25 PM
bluedevil3758's Avatar
ive noticed the exact same thing since i first got the bike
