02 f4i turning over sounds great, won't fire. rode all the time
have an 02 cbr, brand new stator and regulator, ran for 4 months stronggg, just a little rich. So after awhile some of the cyclinders wouldn't fire, as it was burning out plugs. Saw wires in the tire so I put it up, a week later it won't start. Just put brand new plugs in it, charged the battery, turns over like a champ just won't fire. Fuel pump primes, loud as always sounds fine, hellppp?
I would definitely check what you changed out. Unless you changed those things to remedy your current situation. Normally if an engine "all of a sudden" just quits to run... my experience tells me its electrical. Also, you could possibly smell your exhaust for fuel or pull your plugs to see if you are getting fuel. and this might sound stupid but did you make sure you put the plugs in the correct order? Don't these things have a weird firing order? like 1432? or something??
kickstand is down, its in neutral, and the motor is in the on position. the plugs weren't bad i just changed them because when driving before, it definitely wouldnt fire all the cylinders because the running so rich was slowly burning the plugs down. it ran, i put it away because of the chords showing, now i replaced the plugs to install the power commander and have it tuned and now it wont even start. i tried pushing it a few times too, and it sputters but doesnt fire. anyone? id rather not take it to the shop for him to find something small
^ +1. If it wouldnt start after you changed the plugs go back and recheck everything you did make sure the plugs are connected in the right order, check any grounds you might have touched or undone, make sure the battery terminals arent touching anything blah blah blah. Probably a simple problem youre overlooking
