02 f4i turning over sounds great, won't fire. rode all the time
have an 02 cbr, brand new stator and regulator, ran for 4 months stronggg, just a little rich. So after awhile some of the cyclinders wouldn't fire, as it was burning out plugs. Saw wires in the tire so I put it up, a week later it won't start. Just put brand new plugs in it, charged the battery, turns over like a champ just won't fire. Fuel pump primes, loud as always sounds fine, hellppp?
Alright first obvious ones:
1)kick stand down? 2)In neutral 3)Emergency off switch position If those are good how about these: Bad FPR(wet vacuum hose) Coils all plugs in? Gas? |
I would definitely check what you changed out. Unless you changed those things to remedy your current situation. Normally if an engine "all of a sudden" just quits to run... my experience tells me its electrical. Also, you could possibly smell your exhaust for fuel or pull your plugs to see if you are getting fuel. and this might sound stupid but did you make sure you put the plugs in the correct order? Don't these things have a weird firing order? like 1432? or something??
kickstand is down, its in neutral, and the motor is in the on position. the plugs weren't bad i just changed them because when driving before, it definitely wouldnt fire all the cylinders because the running so rich was slowly burning the plugs down. it ran, i put it away because of the chords showing, now i replaced the plugs to install the power commander and have it tuned and now it wont even start. i tried pushing it a few times too, and it sputters but doesnt fire. anyone? id rather not take it to the shop for him to find something small
Try removing the power commander?
PC is not installed yet.
Originally Posted by cbrarin
(Post 981529)
^ +1. If it wouldnt start after you changed the plugs go back and recheck everything you did make sure the plugs are connected in the right order, check any grounds you might have touched or undone, make sure the battery terminals arent touching anything blah blah blah. Probably a simple problem youre overlooking
it actually would start before i changed the plugs, thats why i figured it was them at first, but it def. was not now that i have changed them.
Right - if it would start BEFORE you changed the plugs. But will not start AFTER you changed the plugs. Something probably happened when you were changing them.
