02 f4i front axle?
Old Feb 3, 2013 | 07:05 PM
grunt03's Avatar
New Member
Default 02 f4i front axle?
So I'm working on a 02 F4i project and removed the front wheel. When I slid the axle out, 2 flat washers that are thin fell down from the the right side. Never seen those on a front axle before and looked on a diagram but couldn't find anything. Are they suppose to be on there and where? Thanks
Old Feb 3, 2013 | 10:35 PM
Not original part for sure. Does the bike have the original wheel ?
Old Feb 4, 2013 | 05:43 AM
grunt03's Avatar
New Member
Yes it's the original wheel. The two washers are like paper thin. It doesn't make any sense why they would be on there.
Old Feb 4, 2013 | 10:54 PM
stlcbr600f4_newb's Avatar
yes very odd.... check your bearing on that side.. what about the fork tubes are they OEM??
Old Feb 5, 2013 | 05:37 PM
grunt03's Avatar
New Member
Bearings are good and forks are oem.
Old Feb 5, 2013 | 10:03 PM
looked at a parts break down for both standard and cali model and as suspected they are identical no washers... all i can think is either someone worked on it and found a alignment issue in the forks and corrected it. or after torquing wheel there was undesired play and someone corrected it... just thinking i would put them back when you re-assemble or assemble and check for play in the wheel
adrenalnjunky
F2 For Sale / Trade / Wanted
Nov 23, 2013 11:23 AM
Mbrown2858
F2 Tech
May 4, 2011 02:51 AM
mhianwik
F2 Tech
Aug 11, 2010 03:23 PM
jpierc10
Jul 8, 2008 10:46 AM
daytonatrbo
Oct 5, 2007 03:10 PM
