02 cbr f4i fuel pump won't prime
Old May 13, 2017 | 10:54 PM
keveka2's Avatar
Default 02 cbr f4i fuel pump won't prime
Ok so I have checked basically everything and bypassed everything and what I have currently is no power going to the fuel pump at the three pin connector on the the green is ground and the middle is 9v then the outer brown is 0v which runs the pump the relays click when I turn on and off the kill switch I have bypassed the tps the clutch and kickstand... I have new pump and a new ignition set... I purchased the bike not running/ someone stole the fairings long story do I plugged in the head light assembly and ran awesome... then 4-6months later I got some darings and washed the bike and brought it in the house and put the fairings on and these are my current issues lol.... any ideaS would be helpful??
Old May 14, 2017 | 08:50 AM
74demon's Avatar
Did you remove the tank to put your fairings on? I vaguely remember there being 2 connectors under the tank that can mixed up. Not sure, but worth having a look.
It ran, you put fairings on, and now it doesn't. It has to be something that was touched during the swap.
Old May 14, 2017 | 01:36 PM
keveka2's Avatar
Nope I didn't unplug anything I only washed it and the only wires was the fuel pump wire...open to more suggestions lol ��
Old May 15, 2017 | 10:07 PM
keveka2's Avatar
Any thought as to why the fuel pump relay would click but not fire the pump up ?? Hmm
Old May 16, 2017 | 06:28 AM
74demon's Avatar
is voltage making it out of the relay?
Old May 24, 2017 | 11:07 PM
keveka2's Avatar
I have 4 wires going to relay 2 red and 2 black the larger red had power and the smaller black across from the larger red had power with the relay out installed I tried to jump the wires and the only thing that happens is the Fi light comes on
Old May 25, 2017 | 02:41 AM
CaBaRet's Avatar
Default cut out relay
Hi, which relay are you checking, the Fuel cut relay or the Engine stop relay,
Old May 25, 2017 | 07:18 PM
keveka2's Avatar
Ok blonde moment lol wrong relay 😔 Ok so both black with white wires on the fp relay has power let me try jumping to see if I can get power to the plug for the fuel pump
Old May 25, 2017 | 07:24 PM
keveka2's Avatar
Ok kinda excited I jumped the larger brown wire and the opposing ball and white wire and got a signal to the fuel pump plug now I'm going to check the ground on the plug and should be in business fingers crossed
Old May 26, 2017 | 01:53 AM
CaBaRet's Avatar
I have the same thing happen to me but mine are all Grey moments
