01 f4i pressure in fuel tank?
i recently bought a 2001 f4i after installing a new fuel pump and ignition the bike fires right up, but i did notice it is building pressure in the fuel tank. if i open the fuel cap right after shutting the bike off it has positive pressure in the tank, is this normal? i have heard of the vents being blocked and sucking the tanks in but not enough positive pressure that it almost blows the cap open when i turn the key to open it ?
It's 50 psi at idle, is your bike a california or euro bike? If you don't have a manual you can download one here http://www.stephygee.com/f4imanual.zip.
it is not a cali or euro bike. i ran a wire up the vent tube in the tank and it seemed like it may have fixed the problem. till i rode it today for the first time. i rode about 6 miles and when i got home the pressure was back in the tank. the only other problem i noticed is when the bike has been run and i shut it off, when i start it back up it appears to be running really rich if the bike doesnt stall from idling so low, i barely crack the throttle about 1000 to keep it from stalling,it idles up to about 2 thousand and then drops right back down to the 1300 idle and idles fine and no longer runs rich. this only happens at start up hot. when i start it cold it starts right up at normal idle runs up to 2000 rpm for a few seconds and drops right back down to the normal idle.
knight202
08-11-2012 08:01 AM
Bryantsito
03-25-2012 02:40 PM
