01 F4i keeps blowing starter relays
Old Aug 16, 2018 | 07:49 AM
donkeyf4i's Avatar
Default 01 F4i keeps blowing starter relays
G'day,
I my F4i keeps blowing starter relays, 2 so far. Not sure the origins of the first starter relay, when it blew it i had to replace the plug from the wiring harness because it was melted so badly.
The 2nd starter relay was a cheapy from China (it came with the 15amp fuse, not sure why).
My mechanic thought it might be the regulator/rectifier but did a voltage test while the bike was running and was getting between 13.7 and 14.5 (no higher).
Note: Bike has been made into a stunt bike buy the previous owner with a few extra electronic bits... jet ski kill switch, speedo healer, fans on a switch.
Any insights would be appreciated
Old Aug 16, 2018 | 10:37 AM
74demon's Avatar
Check your cable resistances, starter draw, and grounding points on the battery cable. Resistance causes heat. Everything in the circuit can take more heat than that little spot.
devares28
Feb 7, 2014 07:00 AM
Bryantsito
Mar 12, 2012 04:50 AM
EL Thorsby
May 23, 2011 02:47 PM
flyer_kaz
F2 Tech
May 29, 2010 10:24 PM
Darrylthenewf
Sep 23, 2008 08:56 PM
