01 F4i Front turn signal options
Old Dec 25, 2010 | 08:51 PM
Ratchet831's Avatar
Default 01 F4i Front turn signal options
I am looking to replace the factory front turn signals wil something a little less obtrusive. I am considering the Hotbodies flush mounts, but would like to know if there is a factory style stalked turn signal that doesn't look so cheap like most of the crap I have found so far. Additionally, if I decide to go the signals in the mirrors route, is there a good quality block off plate for the holes left in the farings by the factory signals. Thanks in advance for any info and have a Merry Christmas!
Tim
P.S. - Yes, I did try using the search feature prior to posting.
Old Dec 25, 2010 | 09:23 PM
jp_greenville13's Avatar
Mirrors and hot bodies is a good combination. I have a set of hot bodies if you need some
Old Dec 25, 2010 | 09:59 PM
Ratchet831's Avatar
I saw that, what color lens and does it have the factory ends on them or are those the ones you said you needed to keep?
Old Dec 26, 2010 | 10:45 AM
They've got the clear covers. I can send you the ones with the plugs if you're willing to send me your old plugs. Lol. Either way man. If you're interested shoot me a PM!
Old Dec 26, 2010 | 10:46 AM
Oh, And welcome to CBRF!
Old Dec 26, 2010 | 11:57 AM
supersnake83's Avatar
I have some cheap flush mounts in the front. They get the job done. Mirror turn signals are a nice addition.
My first replacements were some LED arrow lights (again, cheap), but I decided to switch those to flush mounts after a riding season.
Be careful if you just go with flush mounts, because you could have a problem passing your state inspection (if your state has an inspection requirement for motorcycles).
I took a risk sacrifising visibility for look when I got my flush mounts, so safety/visibility when using turn signals is a concern of mine, but I always use a hand signal when in local traffic. I haven't had issues with passing a state inspection here in PA, because my signals just have to work, not be visible for near a 100 feet like some other states.
Good luck with whatever you choose.
Old Dec 26, 2010 | 04:22 PM
gotcbr's Avatar
I'm using HotBodies LEDs w/ smoke lens up front. They are excellent quality & can be wired as 2 or 3-wire lights. They fit perfectly & install easily. You can't go wrong w/ Hotbodies if you're looking for a quality flush mount fit that is very visible.
As for stalk type... I've tried several dif types. One thing is 'generally' true...you tend to get what you pay for. Recently, I picked up a pair of DRC 601 LED's. http://www.drcproducts.com/elect/d45-60-107/index.html . They are excellent quality & bright as well. Many of the offroad guys use these & swear by them. They have adjustable posts/stalks by use of nylon washers. You can add/remove the washers to adjust the length of the post. They can be used for front & back.
Good luck on your decision.
Old Dec 26, 2010 | 11:56 PM
Ratchet831's Avatar
I guess the big question I have after some more research is are the Proton's worth the price premium over the Hotbodies?
Old Dec 27, 2010 | 12:43 AM
Ratchet831's Avatar
Also, after just reading the review stickied at the top of this forum with the review of the euro versions, what is the availability of factory FSport signal assemblies? I like those.
Old Dec 28, 2010 | 10:12 AM
HondaDustin's Avatar
I am also interested in this question, as I recently purchased an 06 F4I with a broken off left turn signal and minorly dinged left fairings. I dont want to go overboard replacing parts, but I do want quality parts. Those Protons look real nice. Is 100 bucks for flush mounts ridiculous? They look nice, plus I like the programmable flash.
