Washers, Washers, we don't need no stinking washers.
Old Apr 17, 2012 | 08:32 PM
Tort93f2's Avatar
Default Washers, Washers, we don't need no stinking washers.
Okay, I took the vacuum chamber covers off while doing my carb cleaning and inspection. When I pulled the jet needle holder and jet needle from the vacuum piston/diaphragm assembly I noticed that only one of the four jet needles had a washer.
Shouldn't they all have washers?
Old Apr 19, 2012 | 01:19 AM
Optimus_Prime's Avatar
Yeah, they should all have a washer, even if everything is stock. Everything on my '93 F2 is stock and having taken the carbs off for a clean this winter I know for certain there are washers on all my jet needles.
Old Apr 21, 2012 | 02:29 PM
Tort93f2's Avatar
Thanks, I talked the mechanic at the dealer today. He said leave the one I have out so none of them have that washer. He said it only effects the high range, high speed. Since I don't plan on racing (at my age) I'm going to run the carbs w/o the washers. If it really effects the bike I guess I''ll put them back in.
Old May 15, 2012 | 09:44 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by Tort93f2
...He said it only effects the high range, high speed...
Well, he's correct and incorrect - leaving the shims out (which is roughly half of one clip position), will "drop" the needles lower, and decrease the amount of fuel for that circuit, the pilot circuit determines your fueling at about 5000RPM to roughly 7500RPM, so, he's close, but it's your midrange that's affected - your main jets determine your fueling at top end.
Old May 15, 2012 | 10:34 AM
Tort93f2's Avatar
JNS, thanks......I'm running the bike without any of the washers/spacers and "seems" to be running fine. I do notice a little hesitation now and again at about 4-5k rpm's but accelerates smooth and strong with no sputtering at the higher rpm's..... I have not had a "tech" sync the carbs so they might be off just a smooge. Thanks
Old May 15, 2012 | 10:44 AM
estate4life's Avatar
February 2012 ROTM
Hey...that's awesome man...bikes running smooth!!!
Soniclight
F2 Tech
Jun 3, 2013 07:22 AM
jmanng
Apr 26, 2010 09:19 PM
Turbulenz
Mar 29, 2010 12:18 PM
Err
Jan 9, 2009 08:15 AM
Johny CBR
Apr 28, 2008 09:23 PM
