Very odd electrical issues.
Old Mar 15, 2012 | 11:04 PM
GarrettSR5's Avatar
Default Very odd electrical issues.
So I thought my R/R was bad. Bought the suggested GSXR one and wired it up tonight.
Had like 12.6V at the battery at idle and 13+ while revving but with a good battery the lights were still bright and dim with the throttle. Went to wally world and bought a new NeverStart. Put it in (did not trickle charge it) and bike fired right up.
Tried to take it for a ride. Things got weirder.
If I put the kickstand down, it would just flat stall.
I pulled the clutch in THEN put the kickstand down and it was fine; is that normal? Out of my 7 bikes, none do this?
So finally got that squared away and went for a ride. I think my petcock is bad so I Have a vacuum line hooked up to it; give it a suck and start it up and the bike runs fine
But when I tried taking it for a second rip up the street, and gave it some throttle and the lights went whacky and the temp gauge pegged
So I shut it off and let it idle again and all was fine. Put some vacuum to the petcock and took it for a ride.
I've got the battery on the trickle charger and will hook up the vacuum tomorrow and see what happens.
Anything else I should check? Sorry for the long winded post!
Old Mar 15, 2012 | 11:26 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Electrical gremlins can sometimes be traced down to a loose ground connection somewhere on the frame.
jordan36
Apr 1, 2014 05:00 PM
Excel
Jul 13, 2012 10:28 PM
JankCibberf2
F2 Tech
Mar 31, 2012 06:19 PM
danl23880
Jul 6, 2010 08:00 PM
camaropower
May 31, 2009 01:55 PM
