testing stator voltage while running
Old Jul 19, 2016 | 02:20 PM
stearnzy's Avatar
Default testing stator voltage while running
I'm trying to decide if I kneed a new stator or not ..I left the stator harness plugged into the rectifier and poked a voltage meter in to a pair of the three yellow leads on the harness I was only getting like 9 volts at idle and managed to get it up to like 15 volts in the upper rpms ....did I test this properly ? and is the stator likely bad...thanks for any help
Old Jul 23, 2016 | 07:51 PM
squale147's Avatar
July 2013 ROTM
Was your dvm on the ac scale??
Old Jul 24, 2016 | 06:53 AM
stearnzy's Avatar
thanks squale..didnt realize these stators were ac voltage ..what the heck ..stator checked out fine when tested on the proper setting
Old Jul 24, 2016 | 08:06 AM
squale147's Avatar
July 2013 ROTM
No problem
BrianCWhalen
Oct 16, 2016 05:45 AM
Patrick Kelley
Aug 25, 2015 09:52 PM
JesseAwesome
F2 Tech
Oct 3, 2011 01:24 PM
Standard89
Mar 19, 2006 07:17 PM
