Stutter under 3000rpm, HELP!
Old Jan 17, 2024 | 08:49 AM
  #51
Hi from Malta, welcome to the forum.
You have jumped onto an 11 year old thread so highly unlikely you will get an answer.
I would suggest that you create a new thread in the relevant section and go from there.
Cheers
Al
Old Jan 17, 2024 | 02:41 PM
  #52
dannoxyz's Avatar
Greetings & Salutations!!! Let's see some photos of your bike.
Does it idle badly after fans turn on? Might be problem with fans using too much power and dropping voltage. Thus taking power away from ignition-system.
Put voltmeter on dash and monitor power-output from charging system. At low-rpms, usually doesn't have enough power to recharge battery AND run ignition at same time. Voltage measurements from before and after fans turn on will be important information for troubleshooting.
Old Jan 17, 2024 | 10:57 PM
  #53
MLA600F2's Avatar
I thought iFound the problem. The bike wasrunning lean on fuel. Yesterday morning was running great. But in the afternoon it started again. Dannoxyz no it s not empty.
Old Jan 18, 2024 | 03:57 PM
  #54
dannoxyz's Avatar
Tank empty?
Old Jan 18, 2024 | 04:08 PM
  #55
Originally Posted by dannoxyz
Tank empty?
That would in fact cause a lean condition.
carlssonlove
Sep 6, 2021 02:34 AM
trabbart
Aug 21, 2020 12:48 PM
Lunchpad
Nov 3, 2018 12:17 AM
Rickyworley.rw
Sep 18, 2017 01:34 AM
Rabin
Mar 7, 2008 09:00 AM
