Stalls when first starting, then runs fine
So recently i bought a CBR600 F2 -94 (my first bike)
i have a quite interesting problem with it. when i start it upp in the morning.
Thing is it runs for about 0.5-1km and then just starts dying just like it out of petrol or the line would be turned of.
But it's on and i have a full tank and it doest help even if i would turn on the Reserv.
Then after it dies it wont start for about 10min.
Feels like it's not getting any gas but i cant figure out why
and after the 10min it starts like nothing happened and can run the whole day without issues.
Untill a couple days later when it happens again.
Allways on the first startup in the morning every couple of days.
So hoping someone might have a idea what might be causing this.
Tips would be appreciated
blockage in fuel line, intank-filter, or carbs need to be cleaned. After you start up the bike and the fuel starts to flow through the carbs more, gunk (if there is any) inside the carbs are disturbed and shift around with the fuel, which could be the cause in your case. Good luck. There is a carb cleaning write up on this forum for the f2.
I had that problem once... kinked the breather hose when I put the tank back on. OP... yours is a textbook description of this.
