Sprockets conversion to 525 for F2 possible?
Old May 30, 2013 | 01:39 PM
Rendez's Avatar
New Member
Default Sprockets conversion to 525 for F2 possible?
Aloha!
I've been reading on and off about chain kits and conversion to 520. I decided to have the best of both worlds, but I'm not sure it fits on my 1994 F2.
The idea is to convert to 525, just like the F3, using JT sprockets from here:
JT Sprockets: Catalogue
The configuration I'd like to try is one down, so 14/43.
Would these sprockets fit if I buy them?
Thanks in advance,
Old May 30, 2013 | 04:51 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by Rendez
Aloha!
Thanks in advance,
Well, you say just like the F3, but specifically, '97 - '98 F3, meaning, the F2 uses the exact same parts as the '95 - '96 F3, and I belive the only thing that changed is the newer F3 went to the 525 chain/sprockets, where the F2 and earlier F3 used 530... the dimensions are otherwise identical.
Anyway, I see no reason you couldn't mount those, as the only difference would be the width. If you want more peace of mind about it, just check the same catalogue listing for the F2, and '95 to '96 F3, and I think you'll see the dimensions are all the same:
Old May 31, 2013 | 04:22 AM
Rendez's Avatar
New Member
Excellent, I´ll check this out and report back, my first upgrade towards F3
Old May 31, 2013 | 08:55 AM
adrenalnjunky's Avatar
Good luck - although if you're thinking of completely converting over everything on your F2 to make it an F3, you're probably better off buying an F3 :-)
Me, I'm trying to turn a Yamaha XS650 into a F2. :-)
Old May 31, 2013 | 11:20 AM
coalminer frank's Avatar
If you're going 525 you may as well go with the standard conversion of 520. But thats just me.
Old Jun 2, 2013 | 08:10 AM
Rendez's Avatar
New Member
Thanks for the advice, good luck achieving the F2 look.
I won't make it an F3. My sprockets are very worn out so I need to replace them. I've read 520 and specially the chains worn out even faster and my bike is for daily use so I'm happy to get a 525 conversion in this case.
The sizes and screws are identical from 91 to 98 so I will go for the JT sprockets of the newer F3 http://www.jtsprockets.com/catalogue/model/4751
I will post pics when done!
shopkins
Apr 24, 2010 10:35 AM
77vetteguy
Apr 13, 2010 04:59 PM
Zach
Sep 18, 2009 04:24 PM
PitbullF4i
Aug 29, 2006 06:44 AM
gtjimm
Jun 29, 2006 03:15 PM
