rejetting carbs jet size with pod filters?
Has anyone out there replaced their jets? What size did you use if you are running pod filters. I have a lot of extra jets lying around from different carburetors I've worked on and rejetted and I don't have a lot of time to put jets in and test ride, then put in different jets and test ride again. I'm not talking about a jet kit with replacement needles and main/pilot jets, I'm just talking about jet size replacement. And I'm just asking what size jets were put in ONLY for the people who have pod filters.
I'm pretty sure you can as long as the carburetor spacing between them allows for it. I put them on my FZR a while back and put a dynojet kit in it. I had to mic the carb air inlet and find the part number for the K&N filters on their website. Even on that one the filters were almost too close to each other, I had to squeeze them on carefully because they bumped each other.
Actually that air box blows, pods would be nice but your going to have to figure out a way to rig that up then figure out how much air you let in then rejet them again. The f3's air box is a much better design than the f2. All they did was add a small tube at the end of the air box where those two hoses are pointing down behind the radiator and make almost like a vacuum box looking thing point directly at the radiator similar to the rx-8's ram air design. I only found the f2's air box was anything decent once i ripped the fairings off.
As for jets, don't worry about wasting money on a jet kit, just find mikouni jets how ever thats spelled, and your golden. those jets are like 2 bucks a piece instead of blowing hundreds on their special jets
