Rebuilding the petcock on your F2
Old Nov 28, 2011 | 07:35 PM
JesseAwesome's Avatar
Default Rebuilding the petcock on your F2
Okay, so I finally got around to rebuild the petcock on my girlfriends bike, and here's the walk through for you all:
First off, what is the petcock? Well you can see it clearly here on the bottom of your tank. It's the fuel on/off/reserve switch, and it's a fairly simple device. It however is vacuum operated, or more like it won't allow fuel to flow unless there is appropriate vacuum. This comes in the form of vaccum created inside the engine cylinders,and when they pull air in through the carbs, they also are creating a vacuum (sucking air) from the petcock to allow the fuel to flow.
So first off, draining the gas. You can do this a variety of ways, but the method I liked to use was hooking up a vaccum hand pump to the petcock, running fuel line into a fuel container, and creating vaccum. This causes the petcock to allow fuel to flow. Now, if your petcock is completely shot, this of coruse won't work, but I've seen that most petcocks don't fail all at once, they fail partially. You should be able to make this technique work, even if it's not an ideal flow.
Next up, remove the petcock assembly from the tank. if you can't figure this one out, you're stupid and should hire a mechanic instantly. I'll give you a hint though... undo the giant nut that is the only thing holding it to the tank.
So here we have the petcock on the left, and the rebuild kit on the right. The rebuild kit on the right was purchased from SDS performance. You can email them to order the kit yourself: sdstigard@gmail.com
Now this is the most important part: Installing it all in the correct order! I've already completed the job at this point, but I took the old parts and placed them so as you can see the order for yourself! PLEASE only refer to this as a last result. This should be a VERY simple process if you take the petcock apart slowly and pay attention to the order in which the original parts went.
The small diaphragm goes on the left, and it's nib connects to the metal cylinder. The metal cylinder goes through the hole in the mid plate (big plate being held up by the needle nose pliers). On the other side of this, you plug the nib in for the large diaphragm. From there, you place the hard small plastic plate, with the spring on it, and finally the last plate where the vaccum itself is applied.
Below are some pictures detailing the order.
(NOTE: In the middle three pictures it should be quite clear that the large diaphragm is warped and beatup. This was the cause of needing to rebuild my girlfriends F2 carbs)
Old Nov 29, 2011 | 10:52 AM
switched's Avatar
Awesome howto! Thanks for taking the time to write that up. :thumbs up
Old Nov 29, 2011 | 06:25 PM
Thanks. Now to see if it becomes a sticky or not.
Old Jan 27, 2012 | 04:37 PM
*BUMP*
A bunch of people found this thread and got in touch with SDS performance to dig up the petcock parts. They've still got a good line on these parts, so if you need them, get ahold of them!
Also, whose dick do you have to suck around here to get a post stickied?
Old Feb 12, 2012 | 01:07 AM
Alright, nobody runs this place I guess. Time to post up some **** or something
Old May 24, 2012 | 01:06 AM
IrishDub's Avatar
New Member
Default People still listening
JesseAwesome
My buddy was trying to get his 91 CBR 600 up and running again after 8 years. We were not getting any fuel from the tank and could not find a good diagram.
From the bike siting for 8 years, the most inside diaphragm was basically glued to the metal housing. So thanks to you, have another rider on the road!
Old Aug 25, 2024 | 05:53 AM
Halimoto's Avatar
Default Looking for pics pls
Hi everyone,
thanks for this superb explanation
Can anyone repost the pics, I can't locate them?
thanks and drive safe
Old Aug 25, 2024 | 08:09 AM
Originally Posted by Halimoto
Hi everyone,
Hey there. That's probably going to be a hard ask. This is a really old thread and the members are no longer active. Also, the mechanism that people used to post pictures back then has changed. That's probably why you aren't seeing them.
Old Aug 25, 2024 | 08:20 AM
Halimoto's Avatar
I was thinking the same but gave it a try
thanks for the reply
caldercay
Jun 20, 2025 02:24 PM
trabich
Apr 10, 2012 05:51 AM
Assortedqtip
Feb 8, 2012 10:16 AM
cbrboyze
Nov 9, 2007 07:54 AM
