-   F2 Tech (https://cbrforum.com/forum/f2-tech-93/)
-   -   Re-tapping a spark plug hole (https://cbrforum.com/forum/f2-tech-93/re-tapping-spark-plug-hole-141504/)
JankCibberf2 Aug 28, 2012 07:00 AM
welp, po never screwed any sparkeys down with a wrench and never told me, just said its ready to go. w/e anyways saved one of the sparkys but number 3 decided t o blow out the head. the threads are still there so im going to try to retap it, but does anyone know the thread pitch of the tap i need? my buddy has a 3/4 or 5/8 tap he uses on cars and is bringin it over but i haz no clue if itll work. i got a spare head to try all sorts of things so im dong that first. also do i need to drop the motor? i currently have the gas tank air filter and radiator off so i can reach i just dun feel like dropping everything out again
JankCibberf2 Aug 28, 2012 11:20 AM
Nothing? welp to the shop
JankCibberf2 Aug 28, 2012 11:06 PM
update. found the right size tap after driving around for hours and after retapping the threads the spark plug still just spins at the bottom. looks like i need a heli coil
gotcbr Aug 28, 2012 11:13 PM
Yep, you're going to need a heli coil.
JankCibberf2 Aug 29, 2012 09:02 AM
The only problem with this is finding the right heli coil set considering are spark plugs are m10 x 1.0 impossible to find in a store, might be online only
OTMRR Aug 29, 2012 09:09 AM
Check these out too.. I prefer them to helicoils..
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
JankCibberf2 Aug 29, 2012 09:33 AM
^^^ya unfortunately im not trying to spend 300 bucks to repair something when i can buy a new head for cheaper
underground-mpyre Aug 29, 2012 10:26 AM
Heli-coils are not always the best with sportbikes with the pressure they make around the spark plugs. Sometimes it causes oil leaks, for I have seen this only twice.
OTMRR Aug 29, 2012 10:54 AM
Yeh they are spendy.. nice though! The spark ones are more than the one i got, I got my M8 for $60 something off Ebay.
The spark ones are twice that... then you gotta buy the inserts..
TIME-SERT Metric Spark Plug Kit M10x1.0 Part # 4010 - Mechanics Tools and Bits
TIME-SERT NEW 4010 M10X1.0 Spark Plug Thread Repair Kit 845617003101 | eBay
JankCibberf2 Aug 29, 2012 11:47 AM
I ended up calling my uncle who works at my grandfathers tool and dye company (I now know what that means and what a coincidence haha) anyways, he put me in contact with this place that sells the entire set i need for 55 bucks so im heading that way after work and i'll let you know whats up
