R/R Plug issue.
Old Nov 11, 2011 | 06:38 PM
GarrettSR5's Avatar
Default R/R Plug issue.
I pulled the R/R off my F2 tonight and besides being covered in lint (bike sat behind a laundromat for a few months), I noticed one of the terminals on the plug (if you were to have the push "lock" facing up it'd be the top left terminal) is burnt up
Could this be my charging issue? How would this happen?
Old Nov 11, 2011 | 06:43 PM
JankCibberf2's Avatar
your r/r sounds to be fried. thats what mine looked like before i replaced it.. btw, why was it behind a laundry mat lol
Old Nov 11, 2011 | 06:44 PM
74demon's Avatar
what about the terminal? is it burned?
yes, it could be the issue. most likely a result of the issue. the regulators go bad and do that quite frequently.
Old Nov 11, 2011 | 07:02 PM
GarrettSR5's Avatar
The R/R terminal looks fine, it's the plug on the bike harness that is fried. I'll post some pics up gimme a minute.
Old Nov 11, 2011 | 07:06 PM
GarrettSR5's Avatar
Pics
Attached Thumbnails R/R Plug issue.-plug-002.jpg   R/R Plug issue.-plug-001.jpg
Old Nov 11, 2011 | 08:05 PM
looks like a burnt out rectifier to me
see
Old Nov 11, 2011 | 09:38 PM
GarrettSR5's Avatar
I just noticed the R/R has heatsink fins. Does this mean it was replaced before?
Old Nov 11, 2011 | 10:54 PM
yessir, does your bike charge properly?
Old Nov 12, 2011 | 07:10 AM
MadHattr059's Avatar
If the bike is running properly and the r/r is a finned heat-sink model, then you probably can get by with just repairing the bike's harness connector.
When I replaced my r/r, instead of replacing the damaged harness connector, I just cut it off and added female bayonets to each of the wires. Then I slipped heat-shrink over each individual to insulate them and plugged each individually into the r/r.
Clean look and with only 5 wires easy to track what went where.
Ern
Old Nov 12, 2011 | 08:57 AM
^^^^ i like his way
