Petcock ?
Old Apr 19, 2010 | 06:51 PM
TooBroke0029's Avatar
Default Petcock ?
well i made a mistake.. i dropped my tank and the petcock wont stop leaking from the side where its riveted. can i just drill those out tap it seal it and screwing it back together?
Old Apr 19, 2010 | 08:30 PM
berga's Avatar
I doubt this has been done by someone here... sounds like an unusual problem. Give it a try and let us know.
Although my guess is that the metal may be too thin to provide adequate support for the threads. Make sure to tap 75% or more if possible.
Old Apr 19, 2010 | 11:33 PM
Default stay question
It seems to be a success! i drilled out the rivets on the **** side found a metal bearing and gasket that had seen better days. i lost a spring inside but i had replacements from harbor frieght tools. i drilled it all the way out found some machine screws and some lock washers put it all together using the orignal gasket. thanks to indian head gasket and the new spring it seems to be better than new. you can actually feel it engage now. i think i found a really inexpensive way of fixing these pos.
I had another question though i just got my f4i stay bracket but it doesnt seem to line up with my 600 rr front fairing from an 05? do i need a different upper stay ?
1992 gsx600f
Mar 10, 2011 12:57 PM
jestr
Feb 15, 2009 11:06 PM
tazshido
Feb 25, 2008 01:56 PM
cbrboyze
Nov 9, 2007 07:54 AM
