Odd Fuelling Problem
Old May 18, 2025 | 06:25 AM
Alfa Male's Avatar
Default Odd Fuelling Problem
Hi all,
I'm working on a friend's 1992 600 F2 which had been laid-up since before Covid...... I'm bringing it back to life for him and have encountered an odd problem. It starts on full choke and will run at idle without issue, but as soon as I try to give ANY throttle or back the choke off the engine dies straight away.
I'm confident the carbs are clean, they spent hours in an ultrasonic tank, and I've had all the jets out. I've proved the needle valves are working and fuel is fresh. Plugs are new and gapped correctly.
It's obviously fundamental and common to all four carbs, but it's got me scratching my head.
Would appreciate any advice from you chaps.
TIA
Old May 18, 2025 | 09:25 AM
Ed Harris's Avatar
Almost certainly the carbs still have blocked internal passageways.
Old May 18, 2025 | 10:06 AM
Alfa Male's Avatar
Thanks Ed, I've found the problem....
The inlet rubbers were/are as hard as rock and I hadn't noticed that when I pulled the carbs off, every one of them had split so the engine was sucking way too much air. Another job to add to the list!
Old May 18, 2025 | 10:33 AM
Ed Harris's Avatar
Ah, I'd assumed that would make itself apparent earlier :-)
When I first took my carbs off the boots didn't survive the experience - it's so much easier now with fresh rubber.
JimmyCBR
Mar 2, 2014 03:41 AM
Chonburi Sam
F2 Tech
May 13, 2012 11:47 AM
intiractive
Sep 21, 2009 03:59 PM
Destinmatt
Feb 2, 2009 09:59 PM
ludespeedny
Sep 18, 2008 01:05 PM
