No power! I need help PLEASE!!!
I ordered a wiring harness for the rectifier. I didn't get to put the on correctly because I didn't have the right equipment.
The bike ran fine. I was trying to put them on there right. During that the red and green wires touched. It was a little spark. Now there is no power. I changed the fuse and it started fine. Then when I turned it off, and tried to turn it back on no power. I tried push starting it. It doesn't work. But I can jump it straight to the starter and it turn right on. I need help. Please!!!
Is your rectifier bad or the plug for it and is all the plugs firmly attached to each other. Sounding like a ground is bad somewhere.
Things to look for;
-Bad rectifier or plug
-Bad starter relay or connection
-Neutral switch solenoid
-Wiring short
-Fuses blown
-Bad Stator
-Bad grounding wire
Wiring Gremlins can cause the most nerve-racking headaches on bikes.
Things to look for;
-Wiring short
-Fuses blown
-Bad Stator
-Bad grounding wire
