Newbie help needed!!!
Old Oct 6, 2013 | 09:14 AM
RUFF/RIDDIN92's Avatar
New Member
Default Newbie help needed!!!
If anybody can point me in the right direction in new to this I just bought a 92 F2 and its was sitting since 2004!
so my question is what type of maintenance would need to be done as far as being cleaned, or changed parts?????
Old Oct 6, 2013 | 03:12 PM
Sebastionbear1's Avatar
All fluids at the very least.
Change oil, oil filter. Drain the coolant system and replace the coolant. Check the hoses carefully for cracks.
Bleed the brake system putting fresh brake/clutch fluid through and again apply the brakes heartily and look for leaks at the seals.
Drain the fuel tank - look for rust in the tank. If there is you may have to dismantle and clean out the carbies. Check the rubber fuel lines and vacuum hoses for perishing/cracks etc.
Check fork seals for leaks - compress the forks a few times and look for weeps out the top of the dust cover/seal area.
Also check wheel bearings and head bearings.
Cheers, SB
Old Oct 6, 2013 | 05:05 PM
gtcole's Avatar
Welcome Crew
Also check the chain, those are neglected often
Old Oct 6, 2013 | 06:37 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
After sitting for 9 years, there are not likely any "ifs", with regards to cleaning the carbs - unless somebody drained the bowls AND blew out all the fueling passages with air, which is highly unlikely, you're going to have some blockage... it may run, but it's probably not going to run well.
Old Oct 7, 2013 | 10:39 AM
New Member
Thanks for all the info keep em comin!!!
Old Oct 7, 2013 | 04:47 PM
gtcole's Avatar
Welcome Crew
9 years... wow. honestly another thing is tires. Tires have a shelf life, and sitting in one spot significantly shortens that. Even if they look ok, unless you know they have been replaced recently, I would plan on getting those. Tires older then 5 years shouldnt be used at all. Unseen damage can occur from that age and lead to bad things. To check the year, look for the last four digits after the DOT. that whole number will be bout 10-12 digits long. You just want the last 4. They tell the week and year produced.
arcotc
Jan 13, 2021 02:45 PM
Kook87
Mar 15, 2012 05:24 PM
Footnfool
Jan 17, 2010 03:53 PM
Slow
Jul 13, 2008 11:10 AM
marbzcbr
Nov 27, 2005 06:13 PM
